Jul 20th, 2024, 11:39pm
Writing and Reading on different files based on Corners (Read 130 times)
subtr
Analog Enthusiast
India
Jan 18th, 2017, 10:09pm
This might not be a relevant post. But it would be great to know if anyone has ever written into a different files using verilogAMS based on the corner simulated in Cadence Virtuoso ADE/ADE XL. I have tried giving filename as variable and parameter in the vams. If anyone has tried this, it would be really great to know how. I would also want to know if reading from different files based on corner is possible as well.
Subtr
AMS_ei
Re: Writing and Reading on different files based on Corners
Reply #1 - Apr 25th, 2017, 9:32am
You can create an OCEAN script and there you can use 'foreach' statement for PVT corners.
Hope this is helpful.
Thank you.
Kind Regards.
