Apr 27th, 2024, 11:08pm
Loop filter Verilog AMS (Read 6522 times)
JeromeONeill
Jan 20th, 2017, 8:14am
I'm new to Verilog AMS and I'm trying to write a simple script for a second order loop filter in Verilog AMS.
Here is the code I have written so far, I am unsure how to join C2 to R1 in order to complete the filter.
Thanks in advance
//Verilog-AMS HDL for "PLLBehav", "Loop_filter" "verilogams"
`include "constants.vams"
`include "disciplines.vams"
`include "Resistor.vams"
`include "cap70pF.vams"
`include "cap500fF.vams"
module Loop_filter (p,n);
ground gnd;
inout p,n;
electrical p,n,a;
Resistor#(.r(5k))R1(p,a);
cap70pF#(.c1(70p))C1(a,gnd);
cap500fF#(.c2(500f))C2(n,gnd);
Re: Loop filter Verilog AMS
Reply #1 - Jan 20th, 2017, 11:19am
Add the following to create a 0V oltage source between p and n:
analog V(p,n) <+ 0;
I am surprised you have two different capacitor definitions. Aren't they the same?
JeromeONeill
Reply #2 - Jan 21st, 2017, 9:57am
Thank you for your help, I have two different capacitor values so I thought I needed two  capacitor modules with the capacitance value for each capacitor declared within each capacitors module. Do I only need one module for a component even if I'm using more than one of them each having a different value? Thanks in advance
-Jerome
Ken Kundert wrote on Jan 20th, 2017, 11:19am:
analog V(p,n) <+ 0;
JeromeONeill
Reply #3 - Jan 21st, 2017, 10:00am
Yes the definitions are the same, I see my mistake now thank you.
- Jerome
analog V(p,n) <+ 0;
Reply #4 - Jan 24th, 2017, 6:56am
If you put V(p,n) <+ 0, doesn't that short out everything else in the module?
Reply #5 - Jan 24th, 2017, 7:00am
According to Annex E (Spice Compatibility) of the Verilog-AMS LRM (version 2.4), you should be able to just instantiate Spice primitives like a resistor and a capacitor:
resistor #(.r(5k)) R1(p,a);
capacitor #(.c1(70p)) C1(a,gnd);
capacitor #(.c2(500f)) C2(n,gnd);
There are also some voltage sources available: vexp, vpulse, vpwl, vsin (no vdc, but all of the sources have a dc parameter, so you just have to set the other parameters properly).
Peng_Li
Hangzhou, China
Reply #6 - Mar 23rd, 2017, 8:45pm
Geoffrey_Coram wrote on Jan 24th, 2017, 7:00am:
Hi, Mr. Coram.
It seems that the primitives Hspice supports doesn't include the voltage sources you just mentioned. The reason for this problem is likely to be the version of Verilog-AMS LRM.
I am using Hspice-2009. It only supports, even Hspice-2014, Verilog-AMS LRM (version 2.2).
Besides this feature, there are also other enhanced functions in later versions, which maybe useful for what I am doing.
Could you give me some advice about which software supports the Verilog-AMS LRM of later version?  (Those similar to Hspice would be easier for me to get started.)
Thanks in advance.
« Last Edit: Mar 24th, 2017, 1:43am by Peng_Li »
JeromeONeill
Reply #7 - Mar 24th, 2017, 7:40am
Cadence Virtuoso supports Verilog  A and Verilog AMS
Peng_Li
Hangzhou, China
Reply #8 - Mar 24th, 2017, 6:55pm
JeromeONeill wrote on Mar 24th, 2017, 7:40am:
Sorry, I didn't make myself clear.
I mean, the version of Verilog-AMS LRM that Hspice-2009 and Hspice-2014 support are version 2.2. The function of this version seems relatively limited. So I am looking for some software which support later version Verilog-A or Verilog-AMS.
(Anyway, thanks for replying.)
Reply #9 - Mar 24th, 2017, 11:59pm
No. It shorts nodes p and n, which essentially makes nodes p and n aliases of each other, but the capacitors and resistors are connecting from p/n to ground, those are not shorted.
In general, I prefer not to use simulator primitives because they are very static. Specifically you cannot change their parameter values with time. I like the ability to do that. That may not be helpful in this situation, but it is really helpful in testbenches.
