Jul 23rd, 2024, 1:26am
Startup time in bandgap refernces (Read 2545 times)
analogy
Feb 07th, 2017, 12:29pm
What should be the rise-time of a bandgap circuit with an enable pin? Should I be worried if for certain rise times to the enable pin of a bandgap reference I see bizarre startup behavior?
Let me know if I need to further clarify my question.
Thanks.
Horror Vacui
Dresden, Germany
Re: Startup time in bandgap refernces
Reply #1 - Feb 11th, 2017, 11:51am
Bizarre is never good. It tells you that there is something unintended.
Otherwise the settling requirement depends on the applciation and the circuitry connected to the bandgap. Can't be said anything in general. Ask your tutor/boss about it.
analogy
Reply #2 - Feb 11th, 2017, 12:06pm
Thank you tzg6sa!
Could you elaborate on some of the applications based on your experiences? Let's say that you have a bandgap reference - now do you directly connect bandgap output to current mirrors? And if so, do you have to worry about sink/source circuit's impedance (and that impedance affecting start-up response of bandgap)?
Horror Vacui
Dresden, Germany
Reply #3 - Feb 16th, 2017, 4:15am
You should know what you are doing and why you are doing so. No one designs a circuit without any idea how it will be used later.
