Sep 21st, 2026, 3:08am
Schematic Model Generator (SMG) tool (Read 5619 times)
Lala878
Feb 27th, 2017, 4:59am
I have recently began working with SMG tool for generating wreal and verilogams model views for my designs.
What I was curious about is if it's possible to generate a pure verilog view (with .v extension).
At first glance from the manual, I think it isn't supposed to be able, but I'm not sure.
Does anyone have any experience with this tool?
Personally, I think it can be handy for some things, but at this point I still prefer handwritten models.
Re: Schematic Model Generator (SMG) tool
Reply #1 - Mar 2nd, 2017, 3:37am
I don't think there's any support for generating pure verilog. There's support for VerilogAMS and SystemVerilog, but of course if you're not using any of Verilog-AMS or SystemVerilog features, you could take the code and use elsewhere.
However, the goal of the tool is primarily for generating real number models.
Lala878
Reply #2 - Mar 8th, 2017, 3:10am
So far I was successful with simplistic models (using Verilog-Editor)
I expect BBTs from analog category if they're just using real values to work ok too.
I didn't find anything about using SKILL with SMG though.
I am facing a major pin change in schematic and it seems that if you update pins in the SMG (they get labeled as "Added by user") you have to manually select their domains.
I wasn't successful in finding pin domains using geGetEditCellView() on a modelSchematic.
Is there a SKILL set for SMG?
Jelena
Reply #3 - Mar 8th, 2017, 9:54pm
Jelena,
There aren't really any public SMG SKILL APIs other than one to start SMG.
For the domain information though, this is defined as a property on the terminal objects:
cv=geGetEditCellView()
foreach(term cv~>terminals
  printf("Term %s has Domain %L\n" term~>name term~>Domain)
