Sep 22nd, 2026, 9:07pm
Piece wise filter in verilogA (Read 3032 times)
deltasigmaADC
Mar 05th, 2017, 10:09pm
        Is there an easy way to implement piece wise linear(in dB scale) filter in verilogA just like how u do in matlab.
eg: [0,100M,200M,500M] -> [0dB, 0dB, -3dB, -10dB] , 0 to 100MHz 0dB. 100MHz to 200MHz gain drops from 0dB to -3dB linear in dB scale. 200MHz to 500MHz drops from -3dB to -10dB linear in dB scale.
Is there an easy way to implement this without giving the pole and zero locations for the filter.
Thanks.
cheap_salary
Re: Piece wise filter in verilogA
Reply #1 - Mar 6th, 2017, 5:13am
deltasigmaADC wrote on Mar 5th, 2017, 10:09pm:
I don't think there is no such usability in MATLAB.
If you have such method in MATLAB, you can realize it by Verilog-A easily.
One possibility is a FIR filter approximation.
