May 4th, 2024, 12:13pm
Trapezoidal ringing in Cadence (Read 143 times)
inqui123
Mar 10th, 2017, 8:51am
Hi
This is with reference to Ken Kundert's book, The Designer's Guide to Spice and Spectre, Chapter4: Section 4.2.2.1-Stiff circuits under Transient analysis. I am trying to understand  the three numerical methods discussed and recreate the graphs shown on page 136-138. The problem is for trapezoidal method, I am unable to see the ringing shown for higher values of pole frequencies. I have tried with very small time constants and very high time steps(forced cadence to follow the required time step only). I changed the settings to Conservative/Liberal and traponly. When I code the same equation in Matlab, the results come as expected. Has the cadence done some error correction for this, and I should indeed not see the trapezoidal ringing in this case?
Re: Trapezoidal ringing in Cadence
Reply #1 - Mar 10th, 2017, 11:02am
Are you properly restricting the simulator to use traponly?
inqui123
Reply #2 - Mar 12th, 2017, 5:52am
I have checked the traponly in transient options. Is there any other setting pertaining to this as well?
Reply #3 - Mar 12th, 2017, 11:42pm
Spectre, and SPICE in general, always places a backward-euler step at corners. This will make it harder to see the effect you seek as it will suppress the trapezoidal ringing.
inqui123
Reply #4 - Mar 13th, 2017, 6:43pm
If I understand correctly, the simulator uses break-points at every sharp corner of the stimuli. This circuit, however, has no such source. It is a rc circuit, with an initial condition.
The idea actually is to understand in which circuit to expect trapezoidal ringing, and if there are some differences between theory and practice.
inqui123
Reply #5 - Mar 16th, 2017, 6:08am
Any update on the question posted?
