May 2nd, 2024, 10:49pm
Singular matrix warning for a global net (Read 153 times)
AMS_ei
Mar 11th, 2017, 8:06am
I have a global net in SPICE netlist. When I run spectre with this SPICE netlist, it is giving warning on this net as a Singular Matrix warning and not able to achieve dc solution.
Is there any special tweak to take care of this?
Thank you.
Re: Singular matrix warning for a global net
Reply #1 - Mar 12th, 2017, 11:44pm
Have you turned off the topology checker?
Does your circuit include Verilog-A code?
AMS_ei
Reply #2 - Mar 21st, 2017, 8:08pm
Hi Ken,
Thank you for your valuable inputs.
Could you please tell me how can I turn off topology checker?
Thank you.
Kind regards.
Reply #3 - Mar 22nd, 2017, 1:44am
I was not suggesting you turn off the topology checker. I was asking if you had turned it off. If you turned off the topology checker, then topology errors would be reported as a singular matrix.
Your going to have to give more information if you want help.
AMS_ei
Reply #4 - Mar 22nd, 2017, 1:29pm
Hi Ken,
Thank you for your interest.
Basically, I have a design in virtuoso and from there, I have extracted spectre netlist using ADE-L. Now, I am using that extracted netlist in my AMS-setup to run a a mixed signal simulation. I am using ams-spectre as a circuit simulator.
I am running irun from command line option and configured it as use=spice in the amsd block.
There is a global net in the extracted netlist. That net is causing the issue with "Singular matrix warning" and after that dc solution is not achieved in a transient analysis.
Could you please comment on this.
Thank you.
Kind regards.
Reply #5 - Mar 22nd, 2017, 4:13pm
Thank you for that information, but none of it is relevant. A singular Jacobian results from trying to simulate a degenerate circuit. So your challenge is to try to identify the degenerate part of your circuit. I recommend you look at that global net and see if there is anything unusual about it or the things that connect to it. This is why I asked about Verilog-A. A bad Verilog-A model may result in a singular Jacobian, but I have also seen people create singular Jacobians using loops of controlled sources. You can also try splitting the net in an attempt to identify the problem.
