Jul 15th, 2024, 11:40pm
Characterization of time-based circuit PFD/TDC (Read 2234 times)
deba
Mar 14th, 2017, 6:36am
For characterizing the dynamic non-linearity of PFD or TDC(so as to calculate SNDR, HD etc), how does one generate two phase shifted signal such that the delay between them varies in a sinusoidal manner. I want to create a verilog-A model for doing this.
Re: Characterization of time-based circuit PFD/TDC
Reply #1 - Mar 14th, 2017, 9:06am
Perhaps something like this ...
module gen(out1, out2)
parameter real tclk=1u from (0:inf);
parameter real freq=1k from (0:inf);
parameter real deltat=500n from (0:tclk);
parameter real tt=10n from (0:inf);
parameter real vout=1;
real o1;
analog begin
    @(timer(0, tclk/2)) begin
	  if (o1 > vout/2)
		o1 = 0;
	  else
		o1 = vout
    V(out1) <+ transition(o1, 0, tt);
    V(out2) <+ transition(o1, tclk + deltat*sin(6.14*freq*$abstime), tt);
I have not actually tried it, but it should be close.
