Aug 31st, 2024, 9:13pm
Spectre netlisting issue with config view (Read 1241 times)
AMS_ei
Mar 18th, 2017, 9:45pm
I have created a config view in which I have kept a subckt definition ( instance I39 as shown in the attachment) as verilog view.
When I generated a netlist by choosing a spectre simulator, I observed that name of the subckt for the instance I39 is vanished and a new word "subcircuit" appears in that place as shown in the attachment.
Could you please explain me is it the issue with the verilog view itself?
or some more settings are required to generate the netlist from config view?
Thank you.
Kind regards,
Re: Spectre netlisting issue with config view
Reply #1 - Mar 20th, 2017, 8:19am
Do you really mean verilog? Spectre can't simulate Verilog (it actually does support structural verilog, but this isn't supported from ADE - not normally needed in an ADE flow) - it does support Verilog A, but not generic Verilog. It's a circuit simulator, not a logic simulator.
AMS_ei
Reply #2 - Mar 21st, 2017, 6:01pm
Thank you Andrew for your valuable inputs.
Yes, I agree with you.
