Apr 30th, 2024, 8:11pm
Pages: 1 2
Stability analysis of a continuous time CMFB (Read 533 times)
polyam
Apr 13th, 2017, 8:21am
I am trying to check the stability of my CMFB. To do so, I am using the test bench (TB) shown in the screenshot. The gm cell is a telescopic OTA and the schematic of the CMFB is also shown. I have several problems and doubts.
1- Am I using a proper TB to examine the stability of the CMFB? I am using cmdmprobe in analoglibe to break the loop. (I tried to follow this tutorial:  https://pdfs.semanticscholar.org/c1dc/91d09c4112cf9aab8baefcc345bd2141fcdd.pdf ).
When CMDM -->1 it measures common mode response
When CMDM -->-1 it measures differential mode response.
2- I don't know how to set the value of the resistors. The way to choose the value of the resistors on the TB is not clear to me.
3- The results I get from the stb analysis is not rational to me. I cannot interpret the results. Please see the stb responses when CMDM is 1 and -1. Is this the way I have to follow to simulate the phase margin of the CMFB?
Thank you
polyam
Re: Stability analysis of a continuous time CMFB
Reply #1 - Apr 13th, 2017, 8:22am
The schematic of the gm-cell
polyam
Reply #2 - Apr 13th, 2017, 8:23am
The schematic of the CMFB.
polyam
Reply #3 - Apr 13th, 2017, 8:24am
STB response when CMDM is 1.
polyam
Reply #4 - Apr 13th, 2017, 8:24am
STB response when CMDM is -1.
Reply #5 - Apr 13th, 2017, 12:28pm
The cmdmprobe has been deprecated. It is inaccurate in certain situations. You should use back-to-back ideal baluns. Alternately, you can use the diffstbprobe.
Your testbench should mimic the circuit in which your amplifier resides. You don't want to know the stability of your amplifier, you want to know the stability of the circuit that the amplifier is embedded in. Asking the stability of the amplifier is the wrong question.
polyam
Reply #6 - Apr 14th, 2017, 11:24am
Hi Ken,
Thank you very much for replying my question. I checked "diffstbprobe" and it seems to be a nice solution. Let me be more clear on my problem and the reason behind my previous question. I am designing a multi-stage (3-stages in my case) amplifier with no capacitor feedforward compensation. Please see the screenshot. Three CMFBs are used to control the CM level. CMFB 1 for gm1, CMFB2 for gm2 and gmp2 and finally CMFB3 for gm3 and gmp3. The op-amp is going to be used in a CT delta-sigma modulator with the active-RC integrator. I performed ac analysis and the system satisfies my specs. I attached the ac response of the op-amp.
I also simulated my CT-DSM  with the op-amp and it didn't work. I suspected that there was something wrong with my CMFBs (CMFB1,2,3). That's why I performed transient analysis on my op-amp and the op-amp gets unstable. Please see the step response.
If I break my op-amp into three parts namely
gm1+CMFB1 ( I already showed this part in my last post)
gm2+gmp2+CMFB2
And gm3+gmp3+CMFB3
I would be able to check the stability of each part individually. (That's what's happening in my head, I don't know if I am truly right).
Having had above explanation, several questions came to me:
1- Am I thinking in a right way? (Checking the stability of individual parts)
If so, What would be a proper test bench and proper analysis?
2- Could you please let me know what I have to do in such a case?
3- Should I put my entire op-amp in a proper TB (in my case an active RC-integrator) and then check the stability of the CMFBs?
Sorry for a bunch of questions!
Many thanks
polyam
Reply #7 - Apr 14th, 2017, 11:25am
AC-response of the 3-stage op-amp
polyam
Reply #8 - Apr 14th, 2017, 11:25am
Step response of the op-amp
Reply #9 - Apr 14th, 2017, 8:18pm
I see no feedback at all.
polyam
Reply #10 - Apr 16th, 2017, 9:21am
Ken,
I attached all screenshots of my op-amp in a single ZIP file.
"3Stage_opamp.png" shows a 3-stage no capacitor feedforward compensation op-amp. gm1, gm2, and gm3 all together make a 3rd order path. gmp2 is located in a 2nd order path and gmp3 is located in a first order path. It shows the topology of the designed op-amp without placing it in any feedback configuration (The transistor level schematics of all above gms are attached).
I also have three CMFBs (please see CMFB.png):
CMFB1 controls the CM level of gm1.
CMFB2 controls the CM level of gm2 and gmp2. (I also attached the schematic of gm2 and gmp2).
CMFB3 controls the CM level of gm3 and gmp3. (Please see the schematic of the gm3 and gmp3 and how they are related together)
Let me review some of my observations:
1- I performed an ac analysis on my op-amp. Please see "ac_response.png". It shows 82 dB DC-gain, 1.8GHz UGBW, and 65-degree phase margin with 3pF load capacitor.
2- I also applied a sin wave to the input of the op-amp. Input amplitude=100uV, input frequency=4MHz.
"in_tran.png" shows the input differential signal.
"gm1_tran.png" shows the tran response at the output of gm1.
"gm2_tran.png" shows the tran response at the output of gm2 (and also gmp2).
"gm3_tran.png" shows the tran response at the output of gm3 (and also gmp3)
The tran response looks logical until 1us and then it seems that the op-amp gets unstable. ( I think there is something wrong with my CMFBs).
Now, I have the following questions:
1- Is what I am guessing correct? CMFBs are not working properly?
2- I want to check the stability of the CMFB (to see the phase margin)  no matter what my previous question is right or wrong. To do so, obviously, I have to put the op-amp in a feedback test bench (TB). Could active RC-integrator be a proper test bench since I am going to use this op amp in a CT delta sigma modulator with active RC integrators?
  2-1 I think I have to use stb analysis to examine the stability of my CMFBs. So, I have to use three diffstbprobes to break the CM loops while op-amp is placed in a TB asked in question 2. Please put me right if I am wrong.
Many Thanks
Reply #11 - Apr 17th, 2017, 1:23am
I'm sorry, but I don't open zip files.
Can you identify the feedback loop or loops?
ULPAnalog
Reply #12 - Apr 17th, 2017, 2:26am
I took a chance to check the content of the zip. My understanding is that the op-amp itself is feedforward compensated with local feedback around gm stages to set the common mode. I have a couple of questions to polyam.
1. Your CMFB has a structure by name single OTA but I do not see what is inside it. Is it a single stage OTA?
2. Did you verify that each OTA with its CMFB is stable? Instead of attacking the 3 stage opamp directly, you may want to first strip it down to a single OTA with CMFB and check if it stays stable. I wonder if the CMFB loop, itself being a two pole system (one from single OTA and other from the pmos device, the gate of which is being controlled by CMFB loop), is adequately compensated.
Thanks and regards
polyam
Reply #13 - Apr 18th, 2017, 8:23am
Sorry ken, I should have guessed that.
I attached the top-level schematic of the op-amp described earlier.
Loop #1: gm1 and its CMFB1
Loop#2: gmp2 and its CMFB2. CMFB2 sets CM level of gm2 and gmp2.
Loop#3: gmp3 and its CMFB3. CMFB3 sets CM level of gm3 and gmp3.
Thank you
Ken Kundert wrote on Apr 17th, 2017, 1:23am:
polyam
Reply #14 - Apr 18th, 2017, 8:25am
Ken,
I don't know if you open pdf files or not. But I've inserted all figures in a single pdf file.
Thank you
Pages: 1 2
