Dec 12th, 2025, 5:49pm
ams netlisting issue using runams (Read 5776 times)
AMS_ei
May 05th, 2017, 12:38am
I am getting an error while generating ams netlist using runams.
I am using the following module:
ies/15.20.014
ic/617/700
The error is attached in the file.
Could anyone please help me out how can I resolve this issue?
Thank you.
Kind regards.
Re: ams netlisting issue using runams
Reply #1 - May 28th, 2017, 2:15pm
This was fixed via CCR 1487801 in IC6.1.7.500.1 (ISR1). You're using the base release (IC6.1.7.78), which didn't have the fix.
I did  see a case (presumably fro you, because the content is almost identical) in which the AE (and R&D) said that the error was benign - but I thought it worth mentioning when this actually got fixed.
Andrew
AMS_ei
Reply #2 - May 29th, 2017, 9:10pm
Hi Andrew,
Thank you for your valuable inputs.
How can I load  IC6.1.7.500.1 (ISR1)?
We have the following modules available:
ic/06.16.140
ic/06.17.700
ic/06.17.705
ic/06.17.706
ic/5141/ISR201102231549
ic/615/ISR15
ic/615/ISR15_ms
ic/616/132
ic/616/132_save
ic/616/ISR5
ic/616/ISR5_ms
ic/616/ISR6
ic/616/ISR6_save
ic/617/700
ic/617/700_old
ic/ams
ic/current
ic/current_ic5
ic/current_ms
ic/latest
ic/prev
ic/test_ms
ic/xps
Which module should I load to overcome the above issue?
This is not mentioned in  CCR 1487801.
Thank you.
Kind regards.
Reply #3 - Jun 1st, 2017, 10:37am
The CCR wouldn't mention the module you need to use, because that's obviously dependent upon what you name them. However, anything after IC617 ISR1 should be OK, and given what you appear to have called them, I'd guess either:
ic/06.17.705
ic/06.17.706
would be OK. (I'm guessing those correspond to 6.1.7.500.5 and 6.1.7.500.6 - the 70x is the "release management system" naming convention on the downloads, if that's what's been followed here.
AMS_ei
Reply #4 - Jun 1st, 2017, 2:44pm
Thank you, Andrew for your valuable inputs.
Kind regards.
