Jul 21st, 2024, 11:23am
body effect (Read 2550 times)
abhilash_172
india
body effect
May 12th, 2017, 5:03am
i have a doubt related to body effect in nmos, i am using 0.18um models , i have given Vds = 1.8v and Vgs = 0.7v and i varied body voltage Vb from -10 to 1v .
As Vb is increased vth decreases ,id increases and as far as vb<0 body source junction is reverse biased,so is = id.
what happens as vb > 0 ? body source junction is forward biased and how id will be changed?
Below is the graph of id vs vbs i got
Maks
San Jose
Re: body effect
Reply #1 - May 13th, 2017, 11:48pm
For Vbs until ~+0.7 V, everything goes as expected - Vt goes down, Id goes up.
After ~0.7V, you are strongly forward biasing source/body diode, and device goes into a crazy non-linear very high current regime. I am not surprised seeing Id going down - it's quite likely that the potential barrier for carriers to go form source to body/substrate becomes lower than the barrier to go into channel, so carriers are redirected from drain to bulk, hence reducing Id. There is no much meaning into biasing the device into this regime, even SPICE models may not be accurate here.
Max
abhilash_172
india
Re: body effect
Reply #2 - May 14th, 2017, 11:25pm
okay it makes sense,since source body junction is forward biased,only some electrons reach the drain end compared to earlier case,hence current is less.
we can also neglect hole current since source is heavily doped compared to body
A Kumar R
India
Re: body effect
Reply #3 - May 17th, 2017, 5:47am
Hi Abhilash,
One question, the graph you provided is a drain current graph vs the body voltage..right?
As you go more negative on the body voltage, i think the current should increase because Vt drops, right?
Please clarify...
