It's also a good idea to mention which version of the simulator you're using, in case this is a known problem. In this specific case there's not enough information to be going on (it's pretty unlikely that all ac simulations fail because that would be picked up prior to the software being released).
However, if you're running an old version of spectre, I'd always suggest trying a recent version just in case the specific issue you're hitting has been solved subsequently.
I was able to run an AC simulation using a simple circuit together with your other statements in SPECTRE161 with no problem at all.
