Hi Frank,
I have a little action in my to-do list to go through the various published articles and update them to reflect the new functionality. Essentially all you have to do in current ISRs is to create the "Spectre" or "Spice" view type, and then when you "check and save" them, it will create everything needed to simulate with that view (by view switching from HED or from the view list in the Setup->Environment form in ADE). You'll get syntax checking in the text editor too...
Anyway, I'll try to move it up my to-do list so that this gets sorted out sooner rather than later.
