Apr 27th, 2024, 2:50pm
Creating a symbol from scs file (Read 94 times)
balshoy
USA
May 11th, 2017, 4:58pm
I have a veriglog A model for a device. Earlier, I used to create a symbol from the verilogA model directly and all values preceded by "parameter" in the code would show directly in the CDF list of the symbol.
Now, I have an scs file that includes the verilogA model in it. I want to be able to create a symbol for that scs file and be able to include the scs file from ADL (model setup)?
Can someone help with that?
Re: Creating a symbol from scs file
Reply #1 - May 28th, 2017, 9:57am
You also posted this on the Cadence Community Forums here: https://community.cadence.com/cadence_technology_forums/f/38/t/37314 and it was answered.
That said, in recent IC617 ISRs (ISR9 onwards) you can create a spectreText view and it will parse the subckt header and create the view-specific CDF so that you can view switch into the text view and it will include the text into the netlist, and ensure that any instance line has the terminals in the right order.
Frank Wiedmann
Munich, Germany
Reply #2 - May 30th, 2017, 4:30am
Hi Andrew,
This sounds very interesting. I just searched Cadence Online Support to find out more about this. Unfortunately, I did not find any documentation about this feature. On the other hand, I found article number 20286246 (https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000uKRXEA2)
stating that the spectreText view is not yet supported by the Hierarchy Editor and the netlisters. Could you please comment on this?
Best regards,
Frank
Reply #3 - Jun 1st, 2017, 10:34am
Hi Frank,
I have a little action in my to-do list to go through the various published articles and update them to reflect the new functionality. Essentially all you have to do in current ISRs is to create the "Spectre" or "Spice" view type, and then when you "check and save" them, it will create everything needed to simulate with that view (by view switching from HED or from the view list in the Setup->Environment form in ADE). You'll get syntax checking in the text editor too...
Anyway, I'll try to move it up my to-do list so that this gets sorted out sooner rather than later.
