My name is Mauro and I am new to this forum. I am a Master student IC designer living in The Netherlands.
This is also my first post
![Smiley Smiley](https://designers-guide.org/forum/Templates/Forum/default/smiley.gif)
Currently, I have the following problem with VerilogA:
I cannot perform PSS simulations due to hidden states.I have read earlier discussions on this forum related to this, I read the document specificly writtin by Ken ("Hidden States in SpectreRF" and tried something myself but it all did not work out unfortunately.
Hereby extra information:
Circuit information:
Oscillation signal (sinewave) has f_osc = 5 GHz
Offset is at Vdd = 1.2V
Amplitude is 0.2V
Voltage range oscillating signal: 1V < Vsignal < 1.4V
Circuit has start-up time (100ns) where Vsignal = Vdd = 1.2V
After that it starts building up oscillation until steady state
Goal of the module: switching off and on at minimum of a sinewave with 1000 periods inbetween
Initially the switch should be conducting (10 Ohms)
Start a counter at steady state oscillation (no counter during start-up) that counts the amount of periods of the sinewave
Stay switched on at the minimum of a sinewave after 1000 periods
Switch off exactly at minimum of a sinewave after 1000 periods
Switch on again at the minimum of a sinewave after 1000 periods etc.
Should operate in PSS&Pnoise analysis with Spectre
Problem: Hidden states in PSS due to r, counter and flag (transient is working)So my input is a voltage sinewave and dependent on that I would like to switch off or on.
My code is in the attachment, please have a look. Otherwise the post would be relatively long, so I wanted to maintain clarity in this way.
I am looking forward to your responses. Thank you in advance,
Mauro
