Dec 13th, 2025, 2:09am
Set the VCO frequency range (Read 642 times)
Gp
May 29th, 2017, 5:19am
Hi All,
I want to design a PLL for 100Mhz cut-off frequency. For this, I want to set the frequency range (Fmax and Fmin) of Voltage controlled oscillator(VCO).
So, How can I decide the frequency range? I mean Fmax & Fmin.
Thanks.
kumar.g
Frankfurt, Germany
Re: Set the VCO frequency range
Reply #1 - Dec 1st, 2017, 2:36am
The VCO range should cover all possible variations including process variations and temperature variation. A thumb rule is +/- 10 % around your  center frequency. If noise is too much of a concern then reduce the (varactor) fine tuning range and use coarse tuning to cover this range
View Profile kumar.g write2rammy   IP Logged
