Sep 24th, 2026, 8:23am
Giving an input DC bias current for an IC (Read 4527 times)
Venky_analog
Analog Design is my
trade. Math is my
love.
TX, USA
May 31st, 2017, 5:25pm
I am trying to give the DC bias current to an IC from an external source. The way I am generating this current is by using a potentiometer structure shown below.
By changing both VDD (tunable) and R1 (potentiometer), I can change the current. The VDD comes from an LDO and hence it's kind of accurate.
The thing is I placed another series resistor R2 to reduce the variations in the current due to possible variations in the potentiometer, as I heard potentiometers are very sensitive to their environments and tend to change with time a lot.
My quesiton is if I keep R2 like 25% of R1, would it be good enough? Also, is this a good way of generating current externally for biasing circuits inside an IC?
Thanks in advance
Either die a white noise or live long enough to see yourself become the 1/f noise.
kabir_fakir
Re: Giving an input DC bias current for an IC
Reply #1 - Aug 30th, 2017, 3:50am
For me it looks fine. I am only concerned about the thermal noise of the resistor itself as you are introducing 2 rsistors
As I did testing with my IC too. to generate the dc current, I took a clean power supply (Agilent- E3644A) and put a huge resistor (in 10k range) in series with that (instead of potentiometer ). And then I keep varying the DC power supply as per requirement of the current.
Always a learner and will be .
