Oct 12th, 2026, 1:37pm
Issue with runams generating netlist (Read 5073 times)
AMS_ei
Jun 09th, 2017, 2:31pm
I am trying to generate netlist using "runams" script.
The netlist is generated successfully but some of the instances have ports binding by order ( not by name).
I am using the following command to generate  a netlist:
runams -lib <lib_name> -cell <cell_name> -view config -netlist -rundir top_run
Is there any other option that I am missing here to generate the netlist in which all the instances will have port binding by name ( not by order)?
Thank you.
Kind regards.
AMS_ei
Re: Issue with runams generating netlist
Reply #1 - Jun 17th, 2017, 11:03pm
When I use ADE-L and generate the netlist usign irun, the generated netlist has port binding by name, which is correct.
Is there any other option to pass through runams that I can generate the same netlist which I have generated using ADE-L using irun?
Also, during this netlist generation, I am looking for .amsbind.scs file.
Can anyone please help me out here.
Thank you.
Kind regards.
Reply #2 - Jul 25th, 2017, 8:14am
I wouldn't expect the naming to be different. One reason might be that you have something in your .simrc which is affecting the defaults?
You can pass -state to give it the ADE state.
The .amsbind.scs should be present in the netlist subdirectory underneath the run directory (passed with -rundir) assuming that the netlist assembly succeeded.
