It looks to me that the drain terminal is vdd!, not "net04", in the schematic you posted.
Obviously, if your drain terminal is connected to a voltage source, then there will be no output noise voltage. Some simulators allow you to get an output noise current directly; others, you'll need a ccvs to convert the current (in the voltage source providing the drain bias voltage) into a voltage.
