Jul 20th, 2024, 5:29am
Theoretical transconductance VS Cadence Spectre simulator transconductance (Read 2774 times)
niloun
Jul 23rd, 2017, 6:12am
I have calculated  transconductance of a NMOS transistor with formula (2*Id/(Vgs-Vth)) and simulated the same circuit in Cadence Spectre with same parameters via two methods, including: 1) DC Analysis>Analog environment>Results>Print>DC operating points
2) plotting derivative of current in respect to Vgs, but Simulation results are different from theory (approximately two times)   Shocked
Would you please explain why does this happen?
« Last Edit: Jul 23rd, 2017, 1:18pm by niloun »
Re: Theoretical transconductance VS Cadence Spectre simulator transconductance
Reply #1 - Jul 24th, 2017, 8:20am
You might try larger devices - sometimes the analytic expressions are affected by short-channel or narrow-width effects.
DanielLam
Reply #2 - Jul 24th, 2017, 9:35am
I agree with Geoffrey. Try longer device lengths (and widths too while you're at it). At least 2-5um length should be good.
Otherwise, if you want the equations to really match up well, you might try going to MOS lvl 3 models (have to make these yourself).
niloun
Reply #3 - Jul 25th, 2017, 1:42am
Geoffrey_Coram wrote on Jul 24th, 2017, 8:20am:
Thanks so much for the answer.
niloun
Reply #4 - Jul 25th, 2017, 1:46am
DanielLam wrote on Jul 24th, 2017, 9:35am:
Yes, Geoffrey is right , Longer device lengths solely solves the problem, The problem was short channel effect.
