Feb 16th, 2026, 10:03pm
hAMSter Model Editor Error Messages (Read 2652 times)
loumbut5
Kenya
Jul 21st, 2017, 9:18am
Hi, sorry for the ambiguous topic but I have just started coding VHDL-AMS today. Smiley
Anyways, I am encountering the following errors while compiling and simulating my code which I am manually translating from SPICE to link with VHDL. Cool
Error : Cannot save/load file "C:\Program Files\Hamster\Lib\\ieee\electrical_systems_pack\electrical_systems.package_bin"
Error : Library "spice2vhd" not found
The first error is beyond me. I don't know what the compiler wants. My directory only goes to C:\Program Files\Hamster\LIB\ieee\ with no electrical_systems_pack directory in the installation.
The second one is confusing since in the LIB directory, I have added the SPICE2VHD file attached.
Though I am not sure if I have saved it correctly since it is two packages in one. Roll Eyes
If you happen to know how to assist, please do. Smiley
View Profile loumbut51   IP Logged
loumbut5
Kenya
Re: hAMSter Model Editor Error Messages
Reply #1 - Jul 23rd, 2017, 10:13am
Ok, I found the problem, I was not loading the proper library.
The new error now is:
\QU2.vhd( 4,???) : Error : Library "spice2vhd" not found
\QU2.vhd( 11,ENTITY qu2) : Info : Entity/Package "qu2" overwritten
\QU2.vhd( 8,ENTITY qu2) : Error : Library "spice2vhd" not found
\QU2.vhd( 9,ENTITY qu2) : Error : Library "spice2vhd" not found
\QU2.vhd( 14,ENTITY qu2) : Error : Simulation object for entity qu2 not created because of 2 errors
\QU2.vhd(???,?] : Error 70015 : error with compiling Undecided
From the code:
library IEEE, SPICE2VHD;
use IEEE.ELECTRICAL_SYSTEMS.all;
use ieee.std_logic_1164.all;
use ieee.math_real.all;
use SPICE2VHD.SPICE_PARAMETERS.all;
use SPICE2VHD.SPICE_COMPONENTS.all;
Please assist.
Regards.
loumbut5
Kenya
Reply #2 - Jul 25th, 2017, 9:42am
Ok, had to recode the whole thing so as not to need the unrecognized library. Tongue
Oh well, it works now. Smiley
Reply #3 - Aug 7th, 2017, 6:24am
Since you did not post your netlist (at least, you indicated you only posted the library), we have no idea how you tried to include that library. Even someone who has used Hamster before would only be guessing.
