Sep 18th, 2026, 9:32am
Dynamic glitch check with spectre option (Read 6293 times)
Gp
Aug 03rd, 2017, 5:25am
Hi All,
I want to use glitch check with spectre (spectre.scs) option. I am using following way but report (.xml) was not generated.
glitch_chk dyn_glitch node=["INV_1"] duration=10n high=1.2
the following message is generated regarding from log file about glitch check :
Design checks inventory:
        dyn_glitch 1
Circuit Check::Setting up dynamic checks...
Circuit Check::Set up dynamic checks done.
Is it the right way or not? if not, kindly suggest me of the proper way of dynamic glitch check.
Re: Dynamic glitch check with spectre option
Reply #1 - Aug 5th, 2017, 1:09am
Based on your previous post, INV_1 is a subckt, not a node - so maybe that's why it doesn't work.
This example works fine:
Vglitch (INV_1 0) vsource type=pwl wave=[0 0 40n 0 41n 1.0 43n 1.0 44n 0 100n 0 101n 1.0 122n 1.0 123n 0.0]
tran tran stop=200n
By the way, I think you might be posting these questions in the wrong forum - I'm assuming you're asking these related to spectre (which is a circuit simulator, not an AMS simulator)?
Not that it matters that much!
Gp
Reply #2 - Aug 5th, 2017, 1:20am
Do I want to glitch check for particular signal? If yes, than how possible?
Reply #3 - Aug 5th, 2017, 1:50am
You appear to be asking me a question that only you can answer - I've no idea if you want to do a glitch check for a particular signal.
If you were looking at a signal called INV_1, it would be what I showed above. If infact your subckt was called INV_1 and you wanted to check (say) a signal called clk inside that, then it would be:
glitch_chk dyn_glitch node=["clk"] duration=10n high=1.2 subckt=["INV_1"]
Gp
Reply #4 - Aug 5th, 2017, 2:21am
It's Working now.
Thanks, Andrew.
