Sep 18th, 2026, 4:32am
Active Inductor simulation (Read 4236 times)
blue111
Aug 09th, 2017, 7:27pm
I am using ngspice to simulate active inductor in https://github.com/promach/frequency_trap
why Vtest = -2 ?
Re: Active Inductor simulation
Reply #1 - Aug 11th, 2017, 6:53am
Perhaps because of the "ac 2" in the source description for the source Vtest? I can't tell the polarity of the source in the schematic.
Reply #2 - Aug 11th, 2017, 10:53am
It is very strange that AC results would be negative. By the default the magnitude should be shown. Did you ask for the real part to be plotted?
mhx
Reply #3 - Aug 11th, 2017, 9:02pm
> why Vtest = -2 ?
(I wonder: Cs=100uF, Cl=1F?)
In case you are doing this with NGSPICE:
the NGSPICE plot command "plot V(test)"
displays -2. (The real part of V(test)).
This is because the positive terminal of
the AC source is grounded.
Try plot abs(V(test)) instead.
-marcel
« Last Edit: Aug 11th, 2017, 11:30pm by mhx »
blue111
Reply #4 - Sep 7th, 2017, 8:23pm
@mhx
is there a way to put 'plot v_ip_out#branch' inside spice-epilog control directive without any syntax error ?
Note: this only works in ngspice interactive terminal, but not in gschem spice-epilog control directive.
