Jul 19th, 2024, 5:22pm
Gain of BiCMOS gm-cell (Read 1914 times)
blue111
Aug 26th, 2017, 5:36am
1) Why Gain @ Node X must be minimized ?
2) Why Ax is equal to ratio of two gm ?
Horror Vacui
Dresden, Germany
Re: Gain of BiCMOS gm-cell
Reply #1 - Aug 29th, 2017, 10:46am
First, you should ask your classmates, or teaching assistant. A real life discussion would help you more.
To be short:
-Miller effect
-because the impedance at node X is 1/gm. You could easily get this if you write the simplest small signal circuit equations.
blue111
Reply #2 - Sep 2nd, 2017, 12:15am
Thanks.
I have not thought of the Miller effect if I have not asked here.
