Sutapanaki,
This is an issue for ViVA not Spectre. There are multiple options for displaying the results. Making some assumptions based on your comments, you did not use save/restart. So both simulations start from time 0. In that case you have a couple of calculator functions available to you: clip() and lshift(). clip() allows you to select the data to be plotted lshift() allows you to shift the data along the time axis
These should provide you what you need.
