Jul 21st, 2024, 11:15am
Port declaration in ADC model (Read 199 times)
samiran
Sep 20th, 2017, 4:45am
I am trying to use the ADC Verilog-A model given in the "Designer's Guide of Verilog AMS" book (Ch. 3, Listing 26). The code is -
// N-bit Analog to Digital Converter
`include "disciplines.vams"
`include "constants.h"
module ideal_adc (out, in, clk);
parameter integer bits = 8 from [1:24];			// resolution (bits)
parameter real fullscale = 1.0;				// input range is from 0 to fullscale (V)
parameter real td = 0;					// delay from clock edge to output (s)
parameter real tt = 0;					// transition time of output (s)
parameter real vdd = 5.0;				// voltage level of logic 1 (V)
parameter real thresh = vdd/2;				// logic threshold level (V)
parameter integer dir = 1 from [–1:1] exclude 0;	// 1 for rising edges, –1 for falling
input in, clk;
output [0:bits–1] out;
voltage in, clk;
voltage [0:bits–1] out;
real sample, midpoint;
integer result[0:bits–1];
genvar i;
analog begin
	@(cross(V(clk)–thresh, +1) or initial_step) begin
		sample = V(in);
		midpoint = fullscale/2.0;
		for (i = bits – 1; i >= 0; i = i – 1 ) begin
			if (sample > midpoint) begin
				result[i] = vdd;
				sample = sample – midpoint;
			end else begin
				result[i] = 0.0;
			sample = 2.0*sample;
	for (i = 0; i < bits; i = i + 1) begin
		V(out[i]) <+ transition(result[i], td, tt);
In this the output port has variable width defined by the integer variable "bits".
The problem that I am facing is - when I am trying to create the symbol (Cadence Virtuoso 6.1.6), it is taking the output port name as out<0:-1>. Changing it to out is not accepted. However, if I set bits = 8, and hard-code the port declaration as -
output [0:7] out;
voltage [0:7] out;
then there is no issue - the port name is taken as out<0:7>.
Can somebody, please help me out in fixing this problem (how to properly set the output port name even after keeping port word-length variable through the parameter bits.
Re: Port declaration in ADC model
Reply #1 - Sep 20th, 2017, 9:15am
ADE does not support parameterized bus widths. You must eliminate the bits parameter and make the number of bits a constant.
samiran
Reply #2 - Sep 20th, 2017, 8:34pm
Thanks for the reply, Ken.
Can the ams simulator handle parameterized bus width?
