Jul 20th, 2024, 11:28am
Comparators input beyond supply rails (Read 1846 times)
niloun
Nov 10th, 2017, 12:33pm
Hi everyone
I have simulated a StrongArm comparator which its inputs are beyond its supply (for instance: Vdd=0.9, Vi+=1.35+0.45*sinwt, Vi-=1.35) and surprisingly it works properly (even in the simulation corners). If it is so, why don't we decrease the supply to save power, what is wrong with decreasing the supply as much as possible for any input range?
Thanks in advance
DanielLam
Re: Comparators input beyond supply rails
Reply #1 - Nov 10th, 2017, 2:22pm
Oxide stress. The Vgs of the input devices can also be > Vdd and runs the risk of overstressing the oxide.
Btw for this nmos input comparator, the higher the common mode, the higher the input thermal noise.
Also, lower Vdd will give lower speed.
niloun
Reply #2 - Nov 10th, 2017, 11:48pm
DanielLam wrote on Nov 10th, 2017, 2:22pm:
THanks DanielLam. I have attached two image from Razavi's survey on StrongArm. So you mean that in phase "b" transistors M1 and M2 receive an unusual amount of voltage which may cause damage to them?
neoflash
Mixed-Signal
Designer
Reply #3 - Nov 14th, 2017, 4:44pm
If you don't need speed from the regeneration latch, you can reduce the supply to save power. Or alternatively, reduce the size of transistor at expense of larger offset.
niloun wrote on Nov 10th, 2017, 12:33pm:
Hi everyone
Thanks in advance
niloun
Reply #4 - Nov 14th, 2017, 11:40pm
neoflash wrote on Nov 14th, 2017, 4:44pm:
Hi everyone
Thanks in advance
Thanks, so there will be no problem if one wants to fabricate this circuit? Since I have heard about issues including : "bulk current" (which I have checked in the simulations and it was OK) or "latch up" or " oxide stress" which Daniel mentioned?
Frank_Heart
Reply #5 - Nov 17th, 2017, 12:08am
If your input device Vgs can handle (Vi+=1.35+0.45*sinwt), you don't have stress problem.
With lower supply for latch, as DanielLam and neoflash mentioned, your dynamic gain is small and speed for latch would be low.
And, how about the supply for the logics after comparator? You probably need a level-shifter to bring the voltage swing to normal supply range.
-Frank
niloun
Reply #6 - Nov 17th, 2017, 1:33am
Frank_Heart wrote on Nov 17th, 2017, 12:08am:
-Frank
Thanks for your answer Frank.
You are right but we can lower the supply of the subsequent blocks and use a level-shifter in the final stage if it is necessary to have the original logic levels. Am I wrong?
Frank_Heart
Reply #7 - Nov 17th, 2017, 8:19am
Niloun, I agree with you. As soon as the overall speed/noise performances meet system requirements. It's a good idea to lower down supply for saving power.
-Frank
