Dear Mr. Salary,
If you search in cdnshelp for "instNamePrefix" it will explain how to do this. In general, adding a cellView property on the symbol (so open the symbol for edit, and then Edit the cellView properties) - the property should be called "instNamePrefix" and the value (it should be a string) should be the prefix you want.
