Apr 25th, 2024, 8:36pm
Default Prefix of Instance Name in Cadence Virtuoso (Read 1447 times)
cheap_salary
Dec 13th, 2017, 5:20am
When I place "analogLib/res" in schematic, an instance name begins with "R".
This is true for "analogLib/cap", "analogLib/ind", etc.
Instance of "analogLib/cap" begins with "C".
Instance of "analogLib/ind" begins with "L".
However my custom instance name begins with "I".
I can not find out any related settings for changing default prefix of instance name in "CIW>Tools>CDF>Edit".
How can I set default prefix of instance name in Cadence Virtuoso ?
Re: Default Prefix of Instance Name in Cadence Virtuoso
Reply #1 - Dec 21st, 2017, 7:38am
Dear Mr. Salary,
If you search in cdnshelp for "instNamePrefix" it will explain how to do this. In general, adding a cellView property on the symbol (so open the symbol for edit, and then Edit the cellView properties) - the property should be called "instNamePrefix" and the value (it should be a string) should be the prefix you want.
cheap_salary
Reply #2 - Dec 24th, 2017, 7:37am
Andrew Beckett wrote on Dec 21st, 2017, 7:38am:
Thanks. This can work.
