Apr 26th, 2024, 2:08pm
Fully Differential Opamp Simulation with Switched Capacitor CMFB (Read 1553 times)
repah
Dec 14th, 2017, 3:36am
I am attempting to simulate this Fully Diffferential Opamp with SC CMFB.
I need to get the SNDR to 70dB.
Should I use Transmission Gates for the Switches shown in the figure below ?  What strategies can I use to increase the SNDR ?
Thank you in advance for advice and tips.
repah
Re: Fully Differential Opamp Simulation with Switched Capacitor CMFB
Reply #1 - Dec 16th, 2017, 11:01pm
My main issues is that when I use transmission gates in cmos for the switches I do not get the SNDR i want - should i use another form of switch like bootstrapped switches for the switches instead?
