iVenky
I am trying to measure the jitter of a clock signal by sending through a transmitter using 11001100 pattern (fclk/2) and 1010 pattern (fclk). First, the absolute RJ should be the same on both cases, right? Also, if I integrate the phase noise over a certain bandwidth, it should be the same in both the cases, right? Also, I am seeing a mismatch in the jitter obtained from a scope (through histogram) and integrated jitter from spectrum analyzer. Is that possible?
