Apr 28th, 2024, 4:39pm
PSS analysis using cadence (Read 1118 times)
Abhishek D
Jan 24th, 2018, 8:42am
Can somebody help me out with the steps involved to obtain the pss analysis in the cadence software in detail. That is, what are the options I need to select in the block.
I've attached the setting file. Please help me out in what things I need to select under the options given.  :)
Re: PSS analysis using cadence
Reply #1 - Jan 24th, 2018, 10:30am
I'm not sure anyone is going to be able to answer your question - you've not described what it is you actually want to simulate (what's the design, why are you running PSS - i.e. what is the aim of your simulation?)
It's too open-ended...
