Jul 21st, 2024, 11:20pm
Transimpedance Ampifier - Input Referred Noise Current Density (Read 797 times)
repah
Jan 30th, 2018, 4:02pm
I am designing a TIA in Cadence, input is current (an idc component), output is voltage (a capacitive load)
I want the input referred noise current density in RMS.
I do a noise analysis.  In the noise analysis, I select the input as my input current, and the output as my output voltage node, referenced to ground.
I run the noise analysis.  When I go to Print->Noise Summary, I select the bandwidth to be 1Hz to my 3dB Frequency of my TIA.  Then, I get the total input referred noise as a number.  I select "V" as my unit.
Is this the Input Referred Noise Current Density in RMS ?
I want to eventually get the average input referred noise current density when I divide this RMS value generated by Cadence by the square root of the 3db frequency of my TIA.
Is this correct, or should I do this in S Parameter analysis ?
Also, not sure if I should run my noise simulation up to the 3dB bandwidth of the TIA or 2X the 3dB Bandwidth as some have suggested.  I ran it to my 3dB Bandwidth.
Thanks.
Re: Transimpedance Ampifier - Input Referred Noise Current Density
Reply #1 - Feb 1st, 2018, 9:15am
The same question was asked and answered on the Cadence Community Forums
