Supports for model groups (binned models) with bsimimg was introduced in MMSIM151 ISR4 - so subversion 15.1.0.434.isr4. It's not related to the IC version.
I just tested this, and see the error you see in earlier versions, but then it works in later versions. You can tell because "spectre -h bsimimg" shows lmin/lmax parameters (amongst others) in the versions where it is supported.
