Jul 21st, 2024, 3:26pm
spectre error in transient analysis of counter example (Read 2872 times)
abhilash_172
india
Feb 19th, 2018, 2:49am
Hi
i am trying to simulate a counter using D flip flops. outputs are coming perfectly upto some time and then simulation log has warning
" zero diagonal found in jacobian" .i am using MMSIM 151.
i attached the screenshot.
abhilash.
abhilash_172
india
Re: spectre error in transient analysis of counter example
Reply #1 - Feb 19th, 2018, 2:50am
virtuoso output log file
Reply #2 - Feb 22nd, 2018, 8:34am
Did you write the code for the D flip flops? (Or where did you get them?)
Do they properly handle mid-rail inputs? If the input is rising, and the simulator happens to pick a timepoint right when the input hits (vdd+vss)/2, do you end up with both the P and N devices off, so that there is no conductance on the output node?
Reply #3 - Feb 23rd, 2018, 7:08pm
A zero diagonal is unusual but it is not an error. The message is printed in the hopes that it might give a clue as to what is happening if something does go wrong, but it in itself is not an indication that anything has gone wrong.
abhilash_172
india
Reply #4 - Feb 25th, 2018, 2:01am
Hi
@ Geoffrey_Coram, i am simulating a D flop using transistors not the verilog code.
1 . in the waveform picture i posted output is coming for sometime, then there is solution error.
2 . tried increasing the cmin value in  spectre options, Now its working fine, but if i run it for really long time again the same issue " zero diagonal found in jacobian".
