Jul 25th, 2024, 1:12pm
VDSAT more than VGS-VTh (Read 4377 times)
cmosa
IIT
Mar 27th, 2018, 1:55pm
Simulating sub 28nm planner technology node IO 1.8V devices.
Device Sizes: W=1u; L=1.5u
Operating points from Spectre sims.
VGS= 730mV
Vth=455mV
VDS= 400mV
VDsat= 330mV
Clearly,  VGS-Vth is 275mV whereas Vdsat is 330mV
I have a very little margin on VDS/VDsat.
If my Vdsat is lower (~275mV as expected), I have enough margin.
I have read and heard that due to channel length modulation effect and/or velocity saturation effect Vdsat is lower than expected VGS-Vth.
however I see VDSAT more than Vgs-Vth !!!
Any explanation for Vdsat > than Vgs-Vth?
Could it be due to metal gate technology?
Could it be some error in the technology file setup since its a relatively new setup for us?
AnalogDE
Re: VDSAT more than VGS-VTh
Reply #1 - May 9th, 2018, 12:42am
Saturation condition for short channel devices isn't going to match square law.  I suggest you look at whatever small signal parameters are of interest to you and make sure those are still OK at your biasing point.
Nyquist
Reply #2 - Jul 10th, 2018, 5:11pm
I think of VDSAT and VGS-TH as two different parameters. VGS-VTH is the overdrive voltage available to me while VDSAT is the voltage that signals the onset of saturation.
Having VGS-VTH < VDSAT means you are operating your transistor in weak inversion/moderate inversion region.
As a rule of thumb, you could also annotate your gmoverid to see if it is > 15. This value might differ for your technology, but it gives a feel for you on where you are operating your transistor.
Can you post the picture of the circuit, you are trying to simulate ?
Also, May I know why the W > L ?
A Kumar R
India
Reply #3 - Jul 23rd, 2018, 11:07pm
I want to understand this topic a little more deeply.
Why is it that a potential difference between Gate-to-Drain(VGD) < Vth of the device ALONE can't saturate the current through the device?
My point is that once we set VGD < Vth, we have created a pinch-off region near the drain-end and this is the on-set of saturation. So, >= 275mV of VDS is enough to saturate then why should we be concerned about a VDSAT of 330mV at all?
are we saying till we hit a VDS of 330mV device won't saturate, why?
Nyquist
Reply #4 - Jul 24th, 2018, 12:34pm
Hi Kumar,
I get your point. Even I felt the same when I started. VGS-VTH = VDSAT is based on the square law. For short channel devices that do not follow square law, VDSAT is no longer equal to VGS-VTH.
you can refer to the discussion here https://www.edaboard.com/showthread.php?321080-What-are-betaeff-and-vdsat-parame....
A Kumar R
India
Reply #5 - Jul 25th, 2018, 8:53am
Can I take it as VDSAT being something independent of VTH of the device?
Nyquist
Reply #6 - Aug 6th, 2018, 11:48am
Hi Kumar,
I am not an expert in device technology. But I would take VTH and VDSAT as independent parameters, just like you mentioned for any technology <0.5um
