maxcy
When I go into the run/simulate tool and edit the test.par file, how do I make these changes take effect when I run a new simulation using the edited test.par file? I assume that the 'save(current buffer)' option is used to save the changes to the edited test.par file. While the 'save as(current buffer)' option will save these changes to the test.par file to a new file which can then be used to 'open' the selected file to run/compile the example. Do I have to 'synchronize' in the run/simulate tool to get this new/changed test.par file to work with the example? I can find no information on this subject in the published information so far.
