Sep 16th, 2026, 6:35pm
applying changes to test.par file in the editor (Read 2068 times)
maxcy
Apr 20th, 2018, 7:55am
When I go into the run/simulate tool and edit the test.par file, how do I make these changes take effect when I run a new simulation using the edited test.par file?  I assume that the 'save(current buffer)' option is used to save the changes to the edited test.par file. While the 'save as(current buffer)' option will save these changes to the test.par file to a new file which can then be used to 'open' the selected file  to run/compile the example.  Do I have to 'synchronize' in the run/simulate tool to get this new/changed test.par file to work with the example?  I can find no information on this subject in the published information so far.
Re: applying changes to test.par file in the editor
Reply #1 - Apr 23rd, 2018, 6:47am
What simulator are you using?
