Oct 2nd, 2026, 5:38am
CppSim Tutorial question using Sue2 (Read 1584 times)
maxcy
Apr 25th, 2018, 10:18pm
In the tutorials (in the CppSim home page) there is one for the 'Design of a Wideband Fractional-N Frequency Synthesizer Using CppSim' and a download file that accompanies the project. I imported the download into the library in Sue2 according to the tutorial. Then I opened up the wb_synth example per instructions. I then did a simple compile/run and ended up with errors. The first error complained about undefined _gl parameters. Looking into the editor I found that the param. line was with no pararmeters, but the commented param line above it looked ok, so I uncommented that line so now I had defined _gl parameters. And recompiled the example. The global errors went away, but now I got the following error:
error in 'eval_no_paren_expr': argument not defined
 in file 'test.par'
  arg = 'enable'
expession = enableerror
 line reads:
→ *Enable the Data Weight Everaging Algorithm 1.0=enable, -1.0=disable
looking again into the editor I find the  following line in the test.par file editor:
*Enable the Date Weight Averaging Alogorithm 1.0=enable, -1.0=disable dwaen=-1.0;
but nothing that seems to relate to the first 5 lines of the error message. I am at a loss of how to fix this example. I would have thought that downloaded examples would work without all these problems! Please help get this running.
