Sep 23rd, 2026, 8:08pm
FFT Plot for Injection Locked PLL output (Read 4007 times)
sarthak
Apr 28th, 2018, 3:55am
I am trying to calculate the phase noise of an injection locked PLL by calculating the DFT of the oscillator output waveform. In the DFT plot I see a lot of spurs appearing due to injection locking. But the amplitude level of spurs follows a sinc type distribution. Can someone explain where this sinc response comes from?
Simulation parameters:
Osc. Freq = 2.56GHz
Ref. Freq = 64MHz
Sinc zero crossing = 16.512GHz
Re: FFT Plot for Injection Locked PLL output
Reply #1 - Apr 28th, 2018, 9:44am
Try using either the direct plot of phase noise or he phase noise calculator function.
sarthak
Reply #2 - Apr 28th, 2018, 11:37am
I thought that the phase noise function works only on the PSS result data but I am using transient noise simulation. Is there a way to use phase noise function on transient simulation data as well?
Reply #3 - Apr 28th, 2018, 11:43pm
No.
deba
Reply #4 - Apr 29th, 2018, 11:47pm
That Sinc probably appears to be the artifact of windowing the data. Does it change with the window length you have for the FFT?
By the way, if you want phase noise you can directly run the driven PSS/PNOISE simulation to check phase noise.
