Dec 15th, 2025, 3:31am
How to calculate phase noise of PLL in cadence? (Read 3031 times)
pashtp
Jun 20th, 2018, 9:41am
I have designed PLL in 90nm and now wants to calculate phase noise for the same. Can anyone suggest steps to calculate it in virtuoso ic 6.1.5?
Re: How to calculate phase noise of PLL in cadence?
Reply #1 - Jun 20th, 2018, 1:55pm
You can use the calculator. Think that the equations are documented
somewhere in the PAKs/app notes. The calculation has been automated
in more recent versions.
The equation is something like,
power spectral density ( absolute jitter)
pashtp
Reply #2 - Jun 20th, 2018, 11:33pm
Yes I found phase noise function. In that function what should be the harmonic number, signal dataset and noise dataset? And i need to select vco output waveform right??
