Sep 17th, 2024, 7:36am
Tow stage Op-Amp common mode feedback (Read 3811 times)
Majid
Jun 23rd, 2018, 1:39am
Hi
I have designed  a two stage Op-Amp. Should I use two common mode feedback  for Op-Amp or one common mode  feedback is enough ??
kumar.g
Frankfurt, Germany
Re: Tow stage Op-Amp common mode feedback
Reply #1 - Jun 26th, 2018, 3:26am
You need to have a common mode feedback for any fully differential (differential input and differential output) high gain stage. Common mode feedback is used to set the output common mode at a sweet spot. So if both the stages have differential outputs then you need two independent common mode feedback.
View Profile kumar.g write2rammy   IP Logged
Jacki
Reply #2 - Jun 27th, 2018, 6:58am
I think you are talking about the general fully-differential miller compensated two-stage opamp. You can either use two separate CMFB loop or you can use only one CMFB loop. If you use one CMFB loop, make sure the input of your CMFB is connected to the output of the two-stage opamp, and check your feedback is stable.
Nyquist
Reply #3 - Jul 10th, 2018, 4:53pm
I agree with Jacki. We can have two CMFBs, one for each stage or we can have have a single CMFB, that takes in output of the second stage and feeds back to the mirrors of the first stage.
vroy_92
Leuven, Belgium
Reply #4 - Aug 12th, 2018, 3:10am
No you don't need two common mode feedback circuits. For example, consider the attached image. The block at the bottom of the circuit is your common mode feedback amplifier. It senses the CM of the output of the second stage and tunes the current of the first stage.
The common mode of the o/p of first stage cannot be fixed as it would still not fix your problem, and you will need to have another CMFB for your output stage. CMFB amplifiers are mighty hard to stabilise, and I never liked going for two of them.
Also the second stage typically has a much larger current than the first stage. For reasonable voltage swings at the output, your devices have to be sized such that they have a small vdsat, which means that the gm of the current source load of your second stage will be high. This will make it hard to stabilize your CMFB loop. [also you lose the advantage of having the Miller pole that can help you stabilise the CMFB loop]
V Roy
dog1
Reply #5 - Aug 21st, 2018, 3:49am
@Vray, I might misunderstand you, but are you saying the figure you attached is not good and we should go for only one CMFB for the first stage?
I disagree with you in that case. In the figure attached, due to feedback, the CM of the output of 2nd stage is fixed, thus the CM of the output of the first stage is fixed by default. Of course, by design, it should be made sure that this CM ensures that all the transistors of the 1st stage are in saturation.
dnw
Reply #6 - Sep 23rd, 2018, 9:40am
I think if I try to change the current in stage1 to change the common mode of stage2. Is not that a problem because stage2 common-mode is weakly dependent on stage1 common mode? Is not that whole idea of common-mode feedback?
Trying to figure out if I am missing something here
vroy_92
Leuven, Belgium
Reply #7 - Sep 29th, 2018, 2:09pm
dog1 wrote on Aug 21st, 2018, 3:49am:
I apologize.. there is a typo and this will work.
V Roy
