Mar 27th, 2023, 12:55am
Any advantage of using both N and P MOS in an LNA? (Read 1018 times)
Horror Vacui
Dresden, Germany
Aug 23rd, 2018, 6:19am
Hi RF designers,
In most of the publications the RF transistors of an LNA are almost NMOS transistors only. If we assume that PMOS devices are fast enough for the operating frequency, would it make sense to employ the PMOS as well?
Thinking in the frame of one stage designs, and assuming that a pmos is a similar transistor than the nmos, we have two devices connected in parallel. So we might have twice the gm but twice the gds as well for the same current, so neither the gain, nor the output noise change.
Here I have assumed that the real part of the output impedance is determined by the output impedance of the transistors. Is it true in general?
For me it is a strange result, that having a pmos as well does not improve the circuit performance.  Could you confirm or debunk the above statement? Can you give examples where using both N and PMOS improves the performance?
Marios
Re: Any advantage of using both N and P MOS in an LNA?
Reply #1 - Sep 20th, 2022, 9:10am
I think that NF is usually independent of device gds. The reason is that both source noise and signal experience same gain. What we are after is to minimize noise added by device itself. This is done by increasing device gm.
In the same manner that adding another NMOS in parallel with the original NMOS increases gm by a factor of 2 (thus decreasing noise contribution by device), adding a PMOS on top of the NMOS inceases gm by a factor of two (assuming gm_p = gm_n). However it is usually achieved without consuming more power (assuming no extra headroom is required).
Marios
