Having the supplies as wreal shouldn't be a problem - the message suggests that you are setting the wreal value on these nets in more than one place - and that's causing the problem.
Without more detail on the circuit configuration and what the models look like, plus which simulator you're using, it's going to be hard to pinpoint it from afar... perhaps you should contact the simulator vendor's support site?
