Minkyu Kim
Hi, I am trying to make some model which uses voltage-dependent parameters with user-defined function in Spectre language. But I cannot find any clues to do such thing in spectre, is it even possible?
I know that there is VCVS or VCCS in Spectre, but what I am trying to do is use the output of the user-defined function in PWL resistors or capacitors. This means that the output type of the function should be parameter.
In addition, I want to have array parameter which could simplify my code for several parameters to be used in the function. Is it possible?
