Apr 26th, 2024, 7:08pm
Voltage dependent parameters in Spectre simulation (Read 1915 times)
Minkyu Kim
Sep 28th, 2018, 7:38am
Hi, I am trying to make some model which uses voltage-dependent parameters with user-defined function in Spectre language. But I cannot find any clues to do such thing in spectre, is it even possible?
I know that there is VCVS or VCCS in Spectre, but what I am trying to do is use the output of the user-defined function in PWL resistors or capacitors.
This means that the output type of the function should be parameter.
In addition, I want to have array parameter which could simplify my code for several parameters to be used in the function. Is it possible?
Re: Voltage dependent parameters in Spectre simulation
Reply #1 - Oct 1st, 2018, 12:01am
Write the model in Verilog-A.
Aditya Raj
Reply #2 - Oct 2nd, 2018, 1:00pm
suggest me tool name of verilog AMS. i have no any idea about verilog AMs tools. so please help me
Reply #3 - Oct 2nd, 2018, 9:21pm
Spectre. Verilog-AMS is a built-in feature of Spectre, and most other simulators designed for analog and mixed-signal ICs.
There are a lot of example Verilog-A models on Verilog-AMS. You can find a how-to on modeling a simple nonlinear component in Varactors.
