Apr 25th, 2024, 10:43pm
Problems with Rand Bit Stream AHDL Block (Read 1267 times)
repah
Oct 27th, 2018, 8:07pm
I want to measure the Eye Diagram of a Broadband Bipolar amplifier I designed.
When I use Rand Bit Stream - i get a lot of errors and the transistor breaking down at BE junction.
I do not get this error with MOS amplifiers.
What can I do - how can I measure the eye diagram of bipolar transistor properly with rand bit stream ?
Thanks.
Re: Problems with Rand Bit Stream AHDL Block
Reply #1 - Oct 28th, 2018, 10:13pm
You've given us very little to go on. Perhaps the transition time of the generator is too fast.
