Sep 17th, 2024, 5:56am
Single Ended Switched Capacitor Opamp to Differential Conversion (Read 657 times)
repah
Nov 28th, 2018, 4:31pm
I designed a single ended opamp sample/hold switched capacitor amplifier with sample capacitors and switches.
I want to convert it to a differential opamp.
What do I do to the current, the sampling caps, size of switches, load capacitance ? Can I just scale these from single ended design ?
Also, add Common Mode Feedback. Is this correct ?
Is this correct ? Did I forget anything ?
Thank you.
repah
Re: Single Ended Switched Capacitor Opamp to Differential Conversion
Reply #1 - Nov 28th, 2018, 4:55pm
This is the circuit I want to make differential.
See attached.
