repah
I designed a single ended opamp sample/hold switched capacitor amplifier with sample capacitors and switches.
I want to convert it to a differential opamp.
What do I do to the current, the sampling caps, size of switches, load capacitance ? Can I just scale these from single ended design ?
Also, add Common Mode Feedback. Is this correct ?
Is this correct ? Did I forget anything ?
Thank you.
